I have code P0306 any help or suggestions?
Code says cylinder #6 misfire I've already replaced spark plugs and coil pack so i dont know what other thing it could be please help
carlosleonardos,The P0306 code means that the cylinder 6 is misfiring or is randomly misfiring. Start by checking for intake leaks. Since you already replaced the plugs and the coil pack there are a more possibilities
# Clogged or faulty fuel injector 6
# Fuel injector 6 harness is open or shorted
# Fuel injector 6 circuit poor electrical connection
# Insufficient cylinder 6 compression
# Incorrect fuel pressure
# Intake air leak
Could i Just buy injector cleaner at an auto parts place and see if that fixes it ??
You could by I have never been impressed with that stuff. Nothing to lose I suppose, so you might as well give it a try.
i waited a couple days to see because i bought an injector cleaner but my jeep is still doin the same thing shakes when im at a light or idle
Then continue down the line with the trouble shooting. i.e. replace injector
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 6,678
