The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Question Closed
Hdmi port problem no connections.
Can anyone help?? I have an PS3 first gen. Power went out the other day for a few seconds, now I found out my hdmi is not getting a connect to the TV. Did my hdmi port went bad or do I have another problem? Power does come on like usual , just don't get signal to the TV I have tried switch hdmi cable out. Thanks in advance.
Add a comment
1 Answer
Chosen Solution
You may try holding down the power button on the ps3 for about 5 seconds. The power bottom should flash and you may hear a beap. Release the power button once you see it flash. By doing this you are resetting the ps3 output mode which may enable the HDMI output again if it is being caused by a software type issue. If resetting the output mode doesn't solve the issue than you may need to disassemble the ps3 to check the HDMI port and motherboard for any issues.
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 61
