Repair information and guides for the iPhone 6 that was released on September 19, 2014. Model Numbers: A1549, A1586, and A1589
4994 Questions View all
After screen replacement screen "crashes"
Hello, yesterday i broke my iPhone screen and after replacement the screen is working fine until 30-40seconds and its "crashes". The screen er turning either red or blue and then turns off. Sometimes its showing blurry colours also.
What could be the problem? Have tried multiple LCD's but still having same problem.
Score 1
3 Comments
we have had same issue in our shop. we didn't have any long screw mistakes either. We are totally puzzled as the phones are difficult to restore even in iTunes.
by
Ok, here's the answer after working on this all day long. You're going to just have to take all the components, button, camera, earpiece etc off your old screen and replace the new components on your new screen replacement. If you're like me you really just wanted to replace a cracked screen anyway. All the other stuff probably still worked but you just thought it would be easier to replace everything at once. It's not a software problem, it's that something - I don't know what - on your new replacement screen isn't playing nice with your old phone. It sucks, I know, but save yourself a lot of time and headaches and just replace everything now. Peace out.
by
i threw away the old screen with the components rip
by
Add a comment
Chosen Solution
Sounds to me like long screw damage if this is after an LCD replacement. Do you think it's possible you mixed up some of the screws while re-assembling the phone? iPhone 6 is very easy to damage if you mix them up. The wrong screw in the wrong hole can ruin motherboard traces. The first thing I would try would be removing all the screws for the LCD connector shield and any other screw you moved on the motherboard when you repaired it. Then see how it operates without those in. Let me know what happens.
2 Comments:
Thanks for the input on this issue but we also did not have a long screw misplaced and still found the iPhone 6 having error 4013. We also tried it in recovery mode and DFU mode just to be safe.
by
Sounds like a software not a hardware issue to me
by
Add a comment
Most Helpful Answer
We have had same issue. On 3 different phones with screens from 3 different vendors. No long screw damage on any of the phones. Very puzzling. When we go to restore in iTunes it throws error 4013
Score 1
1 Comment:
Must of ordered cheap not own parts for your chevy
by
Add a comment
I've had one good boot while having error 4013. What i did, i opened the case and blew some compressed air over it. Then just hung it to a pc and it rebooted right.
Add a comment
the heatgun trick to the headphone jack apparantly did the trick. But i don't know for how long.
1 Comment:
you probably did the heatgun trick on the wifi before to fix wifi. This apparently doesn't fix it all, since it comes back in an error 4013.
by
Add a comment
Add your answer
[deleted] will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 4
Past 30 Days: 11
All Time: 3,677
