will not switch on at all
difficulty switching on and off. will not switch on at all now
Hello Rodney,
it looks like a lot of people are having this issue, i found a possible solution let me know if it works please.
Is your phone rooted? You can try these step to see if you can get it working:
Recovery IMG: http://api.viglink.com/api/click?for...1...
My Phone Died and i can't turn it back on!!! help!!
1. Download the recovery i have posted above. Once downloaded rename to remove the name of the recovery until its just named recovery.img.
2. Plug your device to a computer and run the command
adb reboot
or
adb reboot bootloader
if your device doesn't turn on, then simply pull the battery, put it back in, then redo the steps.
3. Once your phone does power on from one of those commands, reboot into android OS and put the recovery on the root of your sdcard.
4.Boot into bootloader while plugged into the computer and run the following command
fastboot flash recovery recovery.img
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 267
