The April 2014 update of the 11" MacBook Air packs refreshed dual-core i5 and i7 Haswell processors and slightly increased battery performance.
49 Questions View all
Blown resistor capacitor on the motherboard
Hi. I have a 11" Macbook Air and one of it's motherboard resistors had blow up.
http://s1.postimg.org/g2cffygfz/image.jp...
How to fix it?
Thanks!
Comments:
What exact model is your MBA? Give us the last 4 digits of your serial number so we can properly identify your hardware.
by
This is the serial number:
http://s15.postimg.org/int34ynor/image.j...
Where I can get that capacitor from?
by
I'd check with places like Mouser.com or Digikey.com. Of course there are plenty of others. Just a matter of looking around
by
Nothing in there. No idea where to look for it.
by
Check for some with a lightly higher value. You can use some that have higher values, just never lower. A Sanyo 11TJSF62MAIG would be a perfect match. Not easy to find in small quantities. You may have to scrounge on dead circuit boards etc.
by
Show 1 more comment
Add a comment
1 Answer
Chosen Solution
Vilson, that is C7540 which is a 62UF 11V 20% Tantalum - Polymer capacitor in a Case-B2S-1 package. You will have to of course solder the replacement back on. Biggest issue here is why it got damage. usually caused by a short circuit, so you will have to determine the cause of it.
Score 1
Add a comment
Add your answer
Vilson will be eternally grateful.
Past 24 Hours: 1
Past 7 Days: 4
Past 30 Days: 13
All Time: 651
