The first model of iPhone, Model A1203 with 4, 8, or 16 GB capacity and an aluminum back. Repair requires a significant amount of prying, and may require some soldering.
282 Questions View all
My iPhone not on and dont want charge why?
my iphone not on and dont want charge why ??
Add a comment
Chosen Solution
will it power up at all? ie if you connect to wall charger, is it recognised by itunes when you connect with usb? if the battery is dead or dying then only wall power will be enough to boot up. if it is recognised in itunes but no screen display then it may be the lcd is the problem and power is getting through-you just can't see it on the screen.
if not recognised by itunes, doesn't power up with wall charge-check battery (something technical with a voltmeter which has been answered in other questions)
also worth checking cables are seated properly particularly dock connector
check dock connector for damage/dirt in bay-might be if you have dropped the phone?
if it's a sudden problem without damage it's most likely an old battery-most likely if it's the original battery.
hope this is of help.
Score 3
+good answer
The problem is that the program in Aljha stops and does not give any response from the Touch
i need help plz
Add a comment
just hard press from top and bottom at a time while charging. it will sure help.
Add a comment
Add your answer
mody will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,990
