Kindle Fire HD 2013 Black screen but I hear sounds.
My Kindle Fire screen wont come on at all. I here sounds when I hit the power button or adjust the volume and plug and unplug. What could be the problem. LCD?
all you need to do is disconnect the battery and re-connect it. This re-sets the Kindle.... I made a short video here..... https://www.youtube.com/watch?v=dTB_sbNf...
Worked perfectly for me. No need to put it in the oven :) but good starting suggestion. The soft reset procedure with the power button didn't work for me.
thanks a lot for the tip! it worked for me as well, quick and easy
This worked so well! I was about to leave for a trip so i was worried I wouldn't have it. Thank you so much!!
I tried everything to fix my fire tablet only by disconnecting the battery did it finally unfreeze thank you so very much for ur video that saved me
perfect!!! it's year 2022 and I thought my son had broke his tablet ....I went straight to your YouTube video and it worked like a charm!!! On the the first try, thank you so much!!! you were a blessing and an angel in disguise because I thought I was going to lose my mind I have to pay for another tablet LOL THANK YOU THANK YOU SO MUCH
signed,
A loving mother!
I had this problem and just fixed it in a way you won't believe . . . Remove the battery and put tablet in the oven at ~ 120 degrees fahrenheit for 10 minutes! I had posted problem in Google+ forum for the 2013 KFHD and that was suggested. Here's link: https://plus.google.com/1049775360491655...
Boy, was I skeptical, but the tablet screen is now working. Here's detail:
I charged the battery, then removed it. It was REALLY hard to get out. If doing again I'd for sure get iFixit's spudger, but I used a 3/4"-wide length of credit card to get started, then a couple heavy-duty plastic knives. The battery is thin and wants to bend so this has to be done carefully.
I set oven to lowest temp, 150, and used an oven thermometer, (which also had lowest temp of 150, so there was some guesswork involved in getting the temp right.) Anyway, after preheating I turned off oven, let it cool down until thermometer went below 150 (guessing when it was about 120), and then popped in the tablet for 10 minutes, leaving oven off. I let the tablet cool down, reassembled and plugged into computer and voila(!), screen came on. I didn't get the back on tight at first so power button didn't work, but fixed that and now Kindle is working great!
I don't get it. Are you supposed to put the tablet in the oven or the battery? Also, how long should I preheat it for?
LOL, like first line says, put only the *tablet* in the oven after carefully removing the battery (per iFixit diagrams). I preheated for about 10 minutes--doesn't take long to get up to 120 degrees. I turned off oven and left it off because I didn't want it coming on with sudden blast of heat and exceeding 120. Also, I put the tablet screen-side down on a piece of foil laid on a center rack.
This is a way to fix the GPU, which was apparently the problem. See comments near end of the link I left for more info. So cool to have a working screen again!
I was skeptical, but ... I removed my battery, preheated my oven as low as it would go (170) and then turned off the oven and opened the door to get the temp down to ~120. I checked at 8 minutes and found the temp back at 150 so I removed it a minute early. After putting the Kindle back together, it powered right up!
But how did you remove the battery???
Hi,
Just leave the battery for 8 hours not connected and forget the Oven. ;)
you need to hold the off button for twenty seconds i just did it it works. After you press it wait a bit
How do you take out the battery?
Where is it located?
Well I am Currently got The same issue as you you have to take out the battery and put it back in
After changing the battery on my Kindle Fire, I subsequently experienced the same issue with the black screen and beeping sounds from the power and volume buttons. I’ve tried everything suggested, such as the hard reset for 20 seconds, removing the battery connection and even putting the Kindle in the oven for 10 min. but nothing worked. I wonder what I damaged while replacing the battery? If anyone has a guess, I would appreciate the help! Thanks
Past 24 Hours: 7
Past 7 Days: 40
Past 30 Days: 135
All Time: 46,834
1 Comment
What about if it got wet at a hotel room with a leak over the toilet without even knowing it was leaking!!? My fire tablet got wet and it was on at the time... Well I dried it up as good as I could by removing the back of it and undoing the battery.. but when I put it all back together it has a black screen and I can hear the tablet come on but it has no picture at all. Just a black screen.... Help me please 🙏!
by Alex Strong
