Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
Replace 3Gs logic board on 3G?
Can I replace 3Gs board on a the 3G phone? what other part do I need?
Add a comment
Chosen Solution
No, they are simply incompatible with all the rest of the parts.
Score 3
Add a comment
I've tried this too. The main problem you will encounter even if you swap out all the other parts is that the camera module from the 3GS will simply not fit in the cutout in the 3G, making it then impossible to put the screen back in.
Comments:
the dock connector also has an extra connector (no7) for the antenna which is not on the 3gs motherboard!
by
Add a comment
On a side note,
Is it possible to take a front bezel, LCD, digitizer, battery, camera and logic board from a 3G and install it into a 3GS back bezel with everything else in the backing from the 3GS ÉÉÉ
Comments:
Yes, only parts cross compatible are the back and power connector. You'll also need to lift out camera housings... It's just double sided tape and should lift with a fingernail etc
by
Add a comment
Add your answer
MacGeek will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 7,154
