Model A1311 / Mid 2010 / 3.06 & 3.2 GHz Core i3 or 3.6 GHz Core i5 Processor
256 Questions View all
Could changing the GPU fix the issue?
LED 1 is on when I connect a power cable. When I turn on the iMac, LED 2 lights, then LED 3. But LED 4 never lights up and the screen is black. Does this mean that the GPU is damaged and not sending a signal? Could changing the GPU fix the issue?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
1 Answer
Chosen Solution
Please give us he last four figure of your serial number so we can see if this is one that has a recall on it.
Score 1
Comments:
The last 4 digits are 5DNN
I thought this only applied to 2011 iMac? According to this page: http://9to5mac.com/2013/08/16/apple-open...
Where can the problem be since I know you have wrote before that LED 4 must light up on startup signaling that a video signal is present. So there is no video signal? Can the problem be on the logic board and not the GPU? I read some here with the same problem replacing both GPU and backlight module but that did not help the black screen.
by
Add a comment
Add your answer
asle will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 96
