Why I am loosing 1 of memory slot? how to fix?
I have problem with my Macbook Air 13' 2010.
It shows only 1 slot memory of 1067 MHz memory.
it says:
Your Mac contains a single memory slot which accepts a 1067 MHz DDR3 memory module.
How can I fix it?
Everybody knows that we can't upgrade the Macbook Air's memory and according to my serial number it should have 2GB of RAM
I am running OSX 10.9 Maverick with 1GB RAM only
Please help....
Update
According to my serial number it should be 2 gb of RAM. Has anyone has any experience of the same problem?
Comments:
Did you get your system wet?
by
Add a comment
1 Answer
Chosen Solution
Your systems memory is made up of two rows of RAM: 1GB row on the top side and a second 1GB row on the backside of the logic board. Here's a picture of the RAM chips on the top side - 8 chips at the bottom of the image.
What I suspect happened is the other side got wet and the connections on the logic board are now damaged where the RAM rows interconnect.
This may need a new logic board so think about how much you want to put into the system Vs getting a newer system. The SSD can be removed and put into a case so you can still access the data and also create a backup disk!
I would recommend you bring your system to an Apple Store for an estimate.
Score 2
Add a comment
Add your answer
John Rendi will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 87
