There are several types of PowerBook G4 Aluminum models.
878 Questions View all
PB G4 Aluminum, 1.5 GHz ppc: bottom 2/3 screen blanks out
The bottom 2/3 of the screen blanks out until I adjust the screen on its hinges. Problem is getting progressively worse. External monitor does not have same problem, I suspect failing connection?
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
Probably the cable from the logic board to the LCD is going bad since the problem changes when you move the screen. Since I don't know which 1.5 you have I can't leave a link to a specific guide. I am however leaving you a guide to help you pick out your model. Good luck. Ralph
Score 4
Comments:
Oh well fellow - we seem to have anwered at the same time. Point for you ;-)
by
Add a comment
You might have a failing LVDS (video signal) cable. iFixit doesn't seem to have it in stock (correct me if i'm wrong) but you can find one here.
Score 2
Comments:
Add a comment
Add your answer
Darryl will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 559
