Does not boot-or any sign of life-other than battery/AC adaptor
My BTO late 2008 MacBook Pro 2.8GHz laptop has been perfect until last week when it completely died - and died hard. No water damage or any physical external issues...just stone dead.
The battery was discharged with only one light so I plugged it into the original AC adaptor and the battery charged up to full and the Mag connector went from yellow to green by morning. It still would not boot. Other than power to the battery lighting up now full and and the Mag Safe connector changing color the computer shows absolutely no signs of life at all. No clicks, no sounds of any kind and no lights. Total paperweight.
I have tried SMC reset and leaving the battery out for a couple of days. Nothing. completely dead.
Did notice that if I had the battery out and kept the power button down when I plugged in the Mag Safe connector, the light would be dim until the power button was released. I think that tells me that the power switch works-but I cannot get the computer to show any signs of life.
Any ideas?
Comments:
Mayer,
Thank you. Prior to this failure (first since I purchased the machine when new) the 2 year old battery could see about 90 minutes of battery life. Even now, having not been charged for days, it is showing 6 of the 8 lights still lit on the battery indicator on the left side of the laptop when the button is pushed.
Will the laptop not operate even without a battery? If the battery had shorted out I would not expect it to take and hold a charge.
Thoughts?
by
Apple confirmed that it was the logic board that failed.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
If the battery (when charged to 100%) will not hold a 20% of original capacity, the machine will perform as described. Has the battery ever been changed? How long would it run on battery power alone?
Score 1
Add a comment
Add your answer
Larry Paul will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 115
