Released April 2010 / 2.4, 2.53 GHz Core i5 or 2.66, 2.8 GHz Core i7 Processors
516 Questions View all
What does 4SNS/1/40000000:Tm0P-63.375 in the hardware test mean?
I dropped my beloved ProBook, it got a bump in the unibody and the hinge to the screen is slightly off, making it not close properly.
I am devastated...
Noting seems to be wrong, except that the hardware test claims an error called 4SNS/1/40000000:Tm0P-63.375.
What does it mean? Should I expect a horrid expence from trying to have it fixed?
Best wises,
Simen, Norway
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
As I understand it a 4SNS error code indicates a sensor problem. Since the unit was dropped I would open it up and see if any cables are disconnected or loose. Other than that if the computer is working properly I would just continue to use it. Good luck Ralph
MacBook Pro 15" Unibody Mid 2010 Logic Board Replacement
Score 3
Comments:
+ research
by
Add a comment
Very confusing.. but heres what I found on google. If possible, send it in to apple and claim warrenty.
Add a comment
Add your answer
Simen Iversen Vangen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 11
All Time: 2,370
