Repair guides and disassembly information for Apple's Macintosh personal computers.
42762 Questions View all
Trying to use install disk , after putting in new hard drive
Hey, after talking with you last week, I got brave and installed a new Hard Drive in my 2010 MacBook Pro.
I put the install disk and I can't get past the select the disk you want to install.
I tried going through disk utilities to see if it would recognize the hard drive.
It won't go past the language window.
Thanks!!
Score 1
1 Comment
Is every one on vacation?
by
Add a comment
Chosen Solution
Deborah,
Look at these instructions, are they any help?
You can use the part that applies to your case. Such as if you have a disk to install, but don't need to restore from another disk, just use the part that tells you how to partition (GUID is an option found under "Partition").
Score 3
6 Comments:
Thank you Rany, this is my very first time attempting this. I find it very empowering to learn about computers and fixing it myself. Of course I would not have gotten so far without this site. I noticed I can buy what I need here as well.
I did buy an external hard drive to try and restore the info from the old hard drive. Would I first format and partition the new one and then plug in the old one? Thanks
by
I'm happy to say... We did it. I just went for it, somehow I got it right!
Now I'm hoping to get some insight on how to use the external drive to restore some info from my old drive. I'm a Jeweler and have some very important info. on my old drive. Sales receipts, I put together some info. for students amongst other important things I need.
I plugged in the external drive and it just made a funny noise, I'm thinking I have it set up wrong..any help will be much appreciated.
I notice there is a kit for replacing the front of an IPad. I have a crack all the way across. Grandkids!!!!! My husband is a writer and this is his baby!
Thanks again to all that helped!
by
Glad you could do it. Thrilling indeed to be able to take control of your own stuff, specially these days when so much money and reliance go into those pesky machines.
As for repairing iPad glass, it is a real pain but doable none the less.
Finally regarding the recovery of old info, let us first know how it is now:
the old hard drive that was in you computer is now installed in an enclosure and sitting outside your computer?
by
Yes that's right
by
Great. Plug it in using an enclosure (basically a small interface board and a USB cable, with or without a case). You should see the disk appear in the left column of your Finder window or as an icon on your desktop. Click on it, look for a folder named Home Folder, or User, or whatever the user was named in the old system / on the old hard drive. To be on the safe side, copy all that folder from the old drive and paste it on your new/current desktop, then dig in it to look for all the info that you need to recover.
by
Show 1 more comment
Add a comment
Most Helpful Answer
Use Disk Utilities and format the drive, give it one partition. Then install your system.
Score 3
3 Comments:
I've tried that over and over..not sure I'm doing it correctly?
Thank you!
by
Can someone help me understand how to format and partition?
by
Hello, I've been trying to update my computer..but since I put in new hard drive It won't update. It goes through the update process when I hit restart it gets stuck.
Is there a simple solution to this?
MacBook Pro 2010.
by
Add a comment
Add your answer
deborah bergen will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 137
