Why does my computer shut down when tipped or moved?
When I move or tip my computer it shuts down
I have seen this problem once before with a Laptop I fixed. The problem was a loose screw causing the motherboard to short out when jarred. Has your computer ever been opened or worked on? Is it a laptop or a Desktop?
so I opened my laptop x441u and found that one screw to hold the battery was missing. so I put one screw on the battery and make sue its fastened. its just work ! Thanks !
Past 24 Hours: 1
Past 7 Days: 3
Past 30 Days: 9
All Time: 2,017
1 Comment
I have checked the battery sitting as well as all cables on the mother board but the problem still exists. The laptop shuts down when i tap or lift it from the left side where the battery is. I even removed the battery and tested it and this problem remains the same. I tried disconnecting the AC adapter and with the laptop running on the battery , still the same problem!!
Please advise/comment of any other solutions which i may try. Many thanks in advance.
by PEZESHK ABZAR
