2.3GHz, 2.6GHz, or 2.7GHz quad-core Intel Core i7 processor (Turbo Boost up to 3.7GHz) with 6MB shared L3 cache.
561 Questions View all
Question Closed
Is the ribbon crucial to the keyboard connection?
I can't get my keyboard working I have really had a hard time getting the connection in place so now my connection has worn and the ribbon is getting all scratched up due to me trying to insert the cable far enough to lock down. I've given up for awhile have watched a lot of videos and have read a lot of information none seem to help grrrhhh does anyone have the same issue ? Please help much appreciated in advance
Add a comment
1 Answer
Chosen Solution
The ribbon is THE connection for the keyboard. If it is not connected it will not work. It is a tricky ribbon. I usually use a plastic spudger behind the ribbon to help it get curved and then push it in with another spudger. Make sure to not damage the ribbon or the connector. Ribbon damage means new keyboard and connector damage means motherboard repair.
UPDATE by mayer
Here's a guide OT wrote on how to upload images:
Adding images to a new question
Score 3
3 Comments:
Hmmm dam I'm mad at myself learning another expensive lesson I believe the ribbon is damaged then, so I'll replace the keyboard the one thing I didn't want to do. Thank you for helping me geez I hope my mbp runs after this.
by
Post a picture. Don't beat yourself up its just a keyboard ;) I've seen those ribbons go through a lot, it might be just fine you might just need to plug it in right :)
by
Can't figure out how to post pic I've read if I hit edit I'll see an upload icon will keep looking for a way to show you how munted my ribbon is
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 108
