Fifth generation of iPhone. Repair of this device is straightforward, and requires screwdrivers, prying tools, and patience. GSM/CDMA / 16, 32, or 64 GB / Black or White.
2911 Questions View all
iPhone 4s iPhone 3 touch microwaved? after water damage
hi everyone
i just supidly in one rainy morninig tried to dry up my iphone 4s in the microwave for exact 2 sec and then took it out right away as i saw some blink light, then i dried it the normal way, everything is working well except the touch function, no matter what i did cganged to a new screen the same problem persisit, could it be a responsible transistor burnt on the motherboard how can one fix , where to localise it
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
On the image I have put two red circles where most of the components for the touchscreen are located. I would check in those areas and see if you can notice any damage.
Score 2
Add a comment
hi
it helps alot to be sure that its a proplem with the board since i saw a blink when i microwaved it, now the problem is certainly located on the zone shown on the second circle of the picture below . do you think there is something to do about that to be fixed,
thanks
Comments:
Most things can be fixed. It would be just a case of identifying the faulty component and replacing it.
by
Add a comment
Add your answer
strauss s will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 71
