Fix Your Stuff
Right to Repair
Parts & Tools
Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4975 Questions View all
After drop, battery life extremly short and wifi grey out iPhone 6
My iPhone 6 was dropped fairly hard. Everything works like normal except my wifi icon is greyed out and even with a full charge the battery will die within 20-30 minutes of setting it down, if even that long. I have opened the phone and cant see any physical damage to the battery or antenna. I am capable of replacing parts myself but im afraid I dont know which parts are needed.
Please help and thank you in advance.
P.S. the phone is network locked.
Comments:
got the same problem
by
Add a comment
Nintendo Switch Kits
A quick fix to get back in the game
Shop Switch Kits
Shop Switch Kits
Hello Nick! i can help you with the wifi, what is most likely happened is that the wifi anetenna had a big shock of the fall, and might been "jumped" out of it socket, but i have only experiensed this at Iphone 4/4s.
for the wifi antenna see HERE & HERE
i would've changed both the antenna it self, and the cable just to be on the safe side, aswell these are quite cheap products :)
but maybe for the battery you could buy a new one to help it HERE
Im sorry if i was to no help, but good luck buddy! :) Happy fixing ;)
iPhone 6 Top Left Antenna Image
Product
$14.99
iPhone 6 Logic Board Antenna Flex Cable Image
Product
$14.99
iPhone 6 Replacement Battery Image
Product
$29.99
Add a comment
I had the same problem, if the Bluetooth wheel is spinning as well and in settings under wifi address it says NA you'll need to replace you wifi chip, YouTube how to replace iPhone 6 wifi chip and that tell you how to do it, however it requires soldering skills and a lot of effort, best bet if you inexperienced is to take it to a repair shop tell them the problem and get it done there
Hope I helped
Regards
Lucas
Add a comment
Add your answer
nickmaciel2002 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 500
