Released November 2013. 32 GB of Flash Memory. 8GB of RAM. Quad-Core Processor. Identified by model number EGQ307. 7.58 x 4.60 x 0.45 inches. 1080 x 600. 4.5 hours battery life.
13 Questions View all
What do I do when only half of my LCD is working?
When my LCD is on only half of the image is showing on the screen.
Add a comment
Chosen Solution
It sounds like the cable connection is lose. Either that, or your screen is damaged and needs to be replaced. You should try opening your tablet, and removing the screen. Reattach the screen and make sure all the cables are attached to the motherboard. If the problem persists than you will have to replace the LCD. Try using the guide below.
Ematic EGQ307 Digitizer Replacement
Score 1
Add a comment
Most Helpful Answer
This could be caused by 2 problems.
1. If you replaced the LCD it could be the connectors arent fully plugged in.
2. The LCD is going bad and you need to replace it.
Score 1
Add a comment
Add your answer
Ashley will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 2
All Time: 143
