Repair guides for portable MP3 players. These devices play back stored music from hard drives or flash memory.
7469 Questions View all
My MP3 player won't turn on once I remove the charger.
I can listen to my Sylvania SMP2200 2GB MP3 Player when it is charging, but once it unplug it it stops and the light won't turn on. I know it has to be fully charged to play, but it was charging all night. Any tips?
Score 12
Comments:
I have the same problem with my bõrne 2GB MP3 player
by
Add a comment
Most Helpful Answer
I had this problem too its not the battery it must be switched on when charging but plug in your earphones and make sure no music is playing or the battery will be drained and it will result in no charging, That fixed mine hope it helps somebody :p :D
Score 3
Comments:
Thanks! That worked for me! :D
by
I don't understand the steps. Can u explain in more detail? Please....
by
It did not work for me
by
I just got mine today let’s see if it works for me ^-^
by
Add a comment
It sounds to me like you have a bad battery connection or a dead battery. Remove the back cover from the device. Locate the battery and its connector. DO NOT TOUCH THIS!!! It may be round or boxy. Using a spudger if you have one, otherwise use a pencil eraser, push the battery connector back in. Attempt to turn on the MP3 player. If this does not work, then you may have a dead battery.
Score 1
Comments:
Do you think this could happen already? I just got it yesterday.
by
same thing happened to me. I haven't even used it yet.
by
Poor quality control (especially if from a "generic" brand) can pass products that don't work.
by
I just got mine.... is YES a generic brand?
by
my Mp3 player just got broken because of you
by
Add a comment
it sounds like its a case of dead(drained completely and cant be re-charged.) battery
Add a comment
Either try a new charger or get the charging panel replaced.
Add a comment
You could get a portable charger, if nothing already mentioned worked.
Add a comment
Didn’t charge with the charger, but did so with a PC data connection; also the cable was VERY PICKY as to how much i inserted it into the player. Talking 1/10th of a mm. As soon as I got the data connection, it would charge, otherwise a (fake) charging screen. Hope that helps.
Add a comment
I have an answer that works on the MP3 players that you push a switch up to turn it on after you push it up the swith goes down, so my answer is for those MP3 players.
The answer: Hold the power switch up for about 15 seconds, that should make it turn on
Add a comment
Add your answer
anchorsawaybyjulie78 will be eternally grateful.
Past 24 Hours: 19
Past 7 Days: 139
Past 30 Days: 665
All Time: 15,531
