Microsoft's third-generation Xbox game console, released November 22, 2013.
727 Questions View all
Static on xbox one HDMI port seems solid & cable is ok
I'm seeing static on black & white portions of the screen (Static is the best way I can describe it, almost sparkles/changes colors). I've tried different cables & checked the HDMI port & it seems solid as a rock. After it has been on for a little bit it almost goes away but you can still barely see it on white & black sections of the screen. Any ideas what might be causing this.
Score 1
Add a comment
1 Answer
Chosen Solution
The first thing to do would be to clean the port. You can use isopropyl alcohol and a small toothbrush to do this.
If that doesn't help you might consider replacing the cable (even if it works on other stuff).
If that doesn't help then you may need a new HDMI port installed.
I hope this helps.
1 Comment:
Cleaned the port & picked up a new cable. Seems to have fixed the issue. Thanks.
by
Add a comment
Add your answer
sethhusk12 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 10
All Time: 4,220
