Movies, music, multimedia in your home. Use our guides to repair home entertainment devices from surround sound A/V receivers or conventional stereo receivers to power amplifiers, preamplifier, speakers, and iPod/Bluetooth speaker systems.
1867 Questions View all
How can I make a sound system for my TV?
I have found some good speakers, and can run wires from my TV to the otherside of the room through the basement. Can I connect them directly to the TV? If so what type of wire should I use. I have speaker wire but I am not sure if that is the right wire. Do the speakers have to be hooked up to a power source?
Unemployed and board. Thanks, Jan
Score 1
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Well Jan, whether or not the speakers can be directly connected to your TV depends on your TV. Does it have the necessary outputs for speaker connections? If not, most likely you'll need a Audio Receiver, which you can connect to the TV and have the speakers connected to the receiver. the latter option will provide better sound output as well.
Score 2
Add a comment
Add your answer
jan will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 795
