Model A1181: 1.83, 2, 2.1, 2.13, 2.16, 2.2, or 2.4 GHz Core 2 Duo processor
1409 Questions View all
Replace 1 GB memory module with 4 GB?
I have a 2.13 GHz MacBook5,2 (mid 2009) with 2 - 1 GB, 800 MHz memory modules. Would there be a problem if I replaced one of the modules with a PC2-6400 4GB module (IF111-038-1) for a total of 5GB of memory?
Comments:
unibody does not come in 2.13ghz
by
It's a white case, if that helps...
by
Yeah it's not unibody its 1st gen type macbook look down at the answer your good to go !
by
Actually no it does'nt help your telling me unibody it says pro on the question and you have 2.13ghz, open your system profiler hit about this mac and tell me the ghz speed you got too much stuff going in this question.
by
Add a comment
Chosen Solution
No problem with taking it to 5GB.
Your machine is:
Apple MacBook "Core 2 Duo" 2.13 13" (White-09) Specs
Identifiers: Mid-2009 - MC240LL/A - MacBook5,2 - A1181 - 2330
http://www.everymac.com/systems/apple/ma...
RAM Type: PC2-6400 DDR2 Min. RAM Speed: 800 MHz
Details: Supports 800 MHz PC2-6400 DDR2 SDRAM.
Standard RAM: 2 GB Maximum RAM: 6 GB*
Details: 2 GB of RAM is installed as two 1 GB modules, no slots free.
*Apple officially supports a maximum of 4 GB of RAM but third-parties have been able to upgrade the system to 6 GB of RAM using one 2 GB and one 4 GB memory module.
Score 2
Add a comment
If it's the regular first gen macbooks it will take up 6gb and PC2-6400 will work fine.
Score 1
Add a comment
If the ram is upgraded and hard drive is upped to 500GB can you run the latest version of Yosemite??
Comments:
This is an early 2009 Mac Book
by
Add a comment
Add your answer
Wayne Kankovsky will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 3
All Time: 156
