replaced both RAM chips. upgraded to Yosemite, now no firefwire bus
After increasing the RAM to 6 GB. One 4 GB and one 2 GB modules. I then upgraded my OS from Mavericks to Yosemite. Now none of my firewire hard drives are loading, and the system profiler says firewire devices cannot be listed. I have reset the NVRAM and this did not help.
6 Comments
are you use the right speed of ram?
does it show up in disk utility? did you format them when you were doing the upgrade?
by Sunny
While the OP altered the RAM it would not be the factor here as to why the OS upgrade from Mavericks to Yosemite would cause the FireWire port to stop working.
by Dan
I have the correct DDR2 / 800mhz that this model calls for.
There is nothing in the installation instructions that mention formatting or how to do that.
I have OS 10.10.4 now.
One of the three drives does show up in the disk utility app. It doesn't mount and disk first aid won't fix it. If I try to eject the unmounted disk it won't let me. One of the other disks tries to mount, and then there are a string of warnings about improper ejecting and disk may be damaged.
Very strange.
by rio22
That sounds like the power or you pulled the cable while the drive still had pending writes. Apples Disk Utility will only get you so far. I think you'll need something that goes deeper here. I like Drive Genius but there are others out there that will work. Lastly, your drives may need replacing as drives do wear out.
by Dan
Thanks to all of you for your suggestions and input. After a couple more attempts at re-booting various ways, I decided to disconnect all externals from the computer and start over. After start up I powered up each fire wire drive and let it spin up before connecting it to the iMac. In this fashion, one by one I hooked up the chain of drives. Now everybody shows up in the system report, and there are no funny disconnect notices.
Everything seems to right with the World at this point.
Again thanks to everyone for helping with this "head-scratcher".
by rio22
Show 1 more comment
