The Epson WF-2540 is an all-in-one color inkjet printer. It features a 2.5-inch LCD touchscreen and four individual ink cartridges.
will not turn on after having a power outage
my workforce will not power up after a power outage.
Score 2
1 Comment
It may be a problem with your power cord or outlet, if it is plugged into a power strip or similar secondary power source try plugging it directly into the wall.
by
Add a comment
Most Helpful Answer
it has a fuse on the main board that seems to blow easily , if it's completely dead that's probably it , a factory repair costs more than a new printer, don't use the cleaning cycle on these more than once it uses a lot of ink and then clogs the nozzles worse than before
Score 2
2 Comments:
How do I find the main board & fuse
by
Thanks!but where can I find the fuses ?
by
Add a comment
There is no fuse on the main board
Add a comment
Add your answer
greatmother101 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 9
All Time: 5,156
