Admin password pop up crashes the app I'm using.
I'm having trouble with my mac because every time I try to do something that requires admin rights the app I'm using stops being responsive as soon as I click and the popup to enter the admin password should appear (it doesn't). This includes most installers, settings editing and showing my passwords in Chrome.
I honestly have no idea on why it's happening (it has been a couple of weeks doing that now).
Thank you!
MacBook Air (13-inch, Late 2010) running OS X Yosemite 10.10.3.
Add a comment
1 Answer
Chosen Solution
Sounds like your drive is encountering problems. First see if you can make a backup of your apps and data.
Do you have a bootable external drive (USB thumb drive)? If you do try booting up under it and then run Disk Utility to fix the permissions.
If that doesn't fix it you'll likely need to reformat the drive and then re-install everything back.
Score 3
Hi, thanks for the answer!
I did not have any problems with the drive, is it normal that it's giving me problems only when I want to use my admin rights?
I do have a bootable usb (I think) that came with the mac but it has really old software installed (I formatted it some months ago and I had to update the system several times before being up-to-date). I don't think the older version has disk utility, I do have a friend with a newer macbook air (and possibly a newer usb thumb drive with a newer OS), would that work?
By the way, after a looong while I sometimes get the pop up which I didn't get before, but by that time I'd already force quitted the apps so it didn't work, I couldn't type in the password.
Why don't you get a fresh thumb drive (16GB or bigger), then visit your friend with a couple of bottles of wine or beer so you can borrow his laptop to first reformat the thumb drive so its setup with GUID, then download the OS Installer (if he doesn't have it already) from the App Store. But before you run it make a backup copy. Then run it to install the OS onto your thumb drive. Then copy over the OS installer as you may need it. Reboot his system and then hold down the Option key to get to the Boot Manager select your thumb drive to make sure it boots up if it does shutdown his system. Don't forget to finish the wine ;-} Now when you get back home see what happens booting up with your thumb drive running the Disk Utility from it.
It seems like I've got a couple of days when I won't need the laptop, so I'll probably follow your first advice and reformat the drive since I'll have time to initiate the various updates and come back every once in a while. Luckily most of my files are in Google Drive anyway. Thank you so much and sorry for the late reply. I'm also going to take your last advice and go over to my friend's house one of these days. ;)
Add a comment
Add your answer
Giovanni Riva will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 68
