Released October 2008 / 2.4, 2.53, 2.66, 2.8 or 2.93 GHz Core 2 Duo Processor
416 Questions View all
Are there glass removal instructions for the MBP 15" Unibody?
are you able to tell me how i have to proceed to remove the glass from the screen in order to preplace it?
Sommetimes , someone tells that you have to warm up a little bit the border of the glass then pull the glass in the corner with a Suction and a small plastic tool by putting it between the glass and the screan , and sometimes we you don't have to warm glass first .
Thank you for your help.
Add a comment
1 Answer
Chosen Solution
We have that guide for the 13" MacBook Pro Unibody here (steps 15-22). The glass removal is the same procedure as your machine. Once the glass is off, however, there may be a different orientation (especially with screw locations) for further disassembly.
Good luck!
Add a comment
Add your answer
brice06 will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 1,394
