The Apple iPhone 5c was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 8, 16, 32 GB / White, Pink, Yellow, Blue, and Green.
1423 Questions View all
Which could be the problem with my iPhone 5c lcd connectors?
Okay so so i need help determining on what could be the problem with my iphone 5c. one day i was replacing the home button on the phone. Once i finished replacing it and once i turn on the phone the screen doesn't turn on. I had no idea what made it mess up like that. I looked up reviews and it told me the lcd connector is damaged so i would have to replace the screen. And on the other hand other reviews tell me one of the pins on the lcd connector could be damaged (which is a whole nother problem to deal with). Good news is the iphone responds when its conected to itunes.....it vibrates and makes sounds. It vibrates every 5-10 seconds. i was thinking could that be a sign to just get a replacement screen? Im still debating on buying one because that might not even be the problem.
So is there any advice you have for me? Anybody had the same problem? please let me know.
P.s- The phone also heats up on the top right corner (near the camera) and drains the battery, i figured i just need a replacement battery, but maybe not, please let me know!! Thanks
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It could be one thing, it could be a combination of things. You say you replaced the home button, so somewhere along the line of you opening the phone you might have accidentally damaged the connector or the pins.
My advice would be to take it into an Apple store and see what they tell you. Though you may have voided your warranty. Otherwise, you can order a replacement screen and connect it yourself.
Comments:
Thanks for the advice, ill look into it. and another question, what if one of the pins were actually damaged, where would i have to look along the lines to getting it repaired?
by
Add a comment
Can you get a picture of the connections on the logic board?
Comments:
Whats your email? i could send you some pictures from there
by
Add a comment
Add your answer
chris smith will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 94
