Released on September 19, 2014, this 4.7" screen iPhone is the smaller version of the iPhone 6 Plus. Identifiable by the model numbers A1549, A1586, and A1589.
4491 Questions View all
Screen is on but black
So I installed the screen tested it before assembly which worked but when i put it back together the screen was on but only black.
Score 1
Add a comment
Most Helpful Answer
Have you tried holding the home and power buttons down at the same time for roughly 10 seconds?
Have you checked the cable connections to see if they are seated properly?
Score 1
Add a comment
Try disconnecting the battery, while it is disconnected re-seat all of the screen connections so you know they are in all the way. Then hook up the battery and turn the phone on. It should work
If it worked during testing and now it doesn't, then it was most likely an installation error. Check to see if you ripped any of the cables on the screen connections.
Add a comment
Add your answer
alessibiza will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 167
