Made by GM. It's the eighth generation of a land yacht!
21 Questions View all
Why is my bonneville leaking from the driver side?
Bonneville is leaking what I think is power steering or brake fluid. My wheel gets tough to turn corners.
Add a comment
MacBook Battery Fix Kits
Fix Kits Starting at $69.99
Starting at $69.99
Chosen Solution
You've probably broke a line from the steering rack to the power steering pump or the seal has gone in the pump . Are you hearing a whine, if so get this fixed right away before you burn out the pump. A pump is a lot more expensive than a replacement line. DON'T let your pump run out of fluid.
Score 2
Comments:
if its brake fluid you'll be out of brakes soon so be careful
I wouldn't be driving it until its fixed either way
by
Add a comment
If your finding it hard to steer than you probably need a new pump already
Score 1
Add a comment
Add your answer
savage will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 68
