Repair guides, support, and troubleshooting information for MacBook Air models with 13-inch displays.
3660 Questions View all
Question Closed
Screw fixing the mother board of MacBookAir 13"
Hi,
While putting back the motherboard, I screwed too strongly the extreme left screw close the Thunderbold and USB connectors, so the head has broken.
I think it will work without this screw while the main part of the scew is left in the case hole.
Do you advise anything to do ? a small spot of strong glue on the hole place ?
thank you for your support
Regards,
Claude
Add a comment
1 Answer
Chosen Solution
GIRAUD, leave well enough alone. The moment you start messing around with glue, it turns into a mess. If you really want to fix it, remove the board and either try to grab the left over screw with a pair of good pliers, or use a screw extractor.
Score 1
1 Comment:
Thank you for the tips. I will not use glue then...it makes sense.
I have checked on iFixit the kits of screw extractor and pliers.
So far, I think it will work fine without this screw.
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 49
