The Samsung Galaxy Tab 2 10.1 is a 10.1-inch Android-based tablet computer and belongs to the second generation of the Samsung Galaxy Tab series.
110 Questions View all
Problems on Start-up, unit keeps rebooting.
Galaxy Tab-2 10.1: Having an issues on start-up, the table seems to startup fine, is charging fine, but after a minute or two it just reboots itself. Issues just started recently and I haven't loaded any new apps in a while. I haven't noted any recent updates, though they do seem to be updating all the time. Anyone else have experience with this happening? Doesn't seem to matter if I start an app or not, the unit just shuts down and reboots.
Any thoughts?
Will have to try re-installing android I guess.
Score 1
Comments:
Let me know you find a solution for this; I recently replaced a screen on one of these and got the same rebooting pattern. I had to resolder the battery in and it worked...For a bit.
I'm starting to think it's a software issue and not a hardware one, though It's a customer's device and I'd rather know for sure and fix it correctly.
by
I believe it was caused by an interrupted update of some sort. I end up just removing the newest apps one at a time and the problem went away after I removed 3 or 4 apps. (almost, still seems to lock up once in a while, every couple of weeks.) Mobizen was the last app I unloaded. I've since reloaded it with no problems.
by
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Most Helpful Answer
DonStPierre, this sounds more like a hardware issue than a software. The power cycling you describe sound more like you are in need of a new battery. Here you find the guides for it
Score 1
Add a comment
My guess wo knowing more is a power problem
Add a comment
Add your answer
DonStPierre will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 469
