Dead MacBook Replace Fuse?
Hi all,
Recently I got a MacBook Pro mid 2009 (13,3") that won't start any more. The device does absolutely nothing. The only thing that does work is the battery indicator but only when the magsafe connector is supplying power. It gives all 6 leds, but after I disconnect the charger it gives nothing. I treid SMD reset and starting the machine by shorting the powerpads.
I opened up the MacBook to check the fuses and when checking the brown fuse (which can be found in the pictures attached) doesn't let thru any power. Would my best bet be to replace the fuse? And does anyone know what specific fuse this is?
