frozen slide bar even after downloading current softwear
The current software is uploaded, 4.0.1
Itunes is current 9.2.1.4
Quicktime is current 7.6.6
Bonjour 2020
Still cannot turn the phone on.
Bonjour 2020
only to get this straight - you try to power the ipone on but you can't use the "slide to unlock" - right ?
any droppings or fluid damages ?
i would start with a hard reset - press and hold the sleep and the home button until the iphone restarts - this should take around 10 seconds. if it works - good, if not disassemble the phone and reseat the digitizer connection. if that still won't work - the digitizer most likely died and you need to replace the front panel
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,826
3 Comments
Does the phone respond to any touch? Try shutting the phone down, and see if you can slide the "power" slider.
by Alex Jansen
What is your iOS device?
by Tri Emil Alim
iPhone 3G, He tagged it ----->
by Alex Jansen
