Repair information and guides for the Apple iPhone 5s that was announced on September 10, 2013. Model: A1533, A1453, A1457, A1528, A1530, A1518
3530 Questions View all
Question Closed
iPhone doesn't respond at all.
Hey iFixit members!
I do have a big problem with iPhone 5s I was using.
So the phone doesn't charge. (which is kinda weird, because the phone looks almost new, always been in a case, and never dropped or opened) I checked the lightning port on iPhone, and it was clean. As you can see.
It works only with one cable. I have tried almost 10 different cables and still it didn't work.
I work a lot with iPhones, as I'm changing screens and batteries usually, still i haven't never experienced this kind of problem.
What can cause this problem? Thanks!
Add a comment
Chosen Solution
If it is not charging at all with any of the original cables and/or does not connect to iTunes on your computer and/or works ok on a new charged battery, but won't restart once battery is empty, then you probably have a failing U2 USB charging/control IC.
You should rule out charging dock failure by trying a new known good one (no need to remove the old, just disconnect it, overlay the new one over it, and plug it into the board and test).
Score 2
1 Comment:
How it can be broken? And thanks, ill order it =)
by
Add a comment
Have you tried using the different cables that does not work, both "front" and "back"?
If they work one way but not the other, it's either a missing or bent pin in the iPhone's Lightning dock, thus you'd need a replacement lightning dock, ans Rany said. So deffinately try that.
Score 2
1 Comment:
Thanks for your comment! Yeah, I have tried with all kinds of chargers..
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 161
