The Apple iPhone 5s was announced on September 10, 2013. Repair of this device is similar to the previous models, and requires screwdrivers and prying tools. Available as GSM or CDMA / 16, 32, or 64 GB / Silver, Gold, and Space Gray.
3638 Questions View all
Screen is blank and the phone won't do anything.
So this happened a couple months ago and I've just now got fed up with my replacement phone and want to fix this one. I'm pretty sure that it's a problem with the battery but I just want to make sure. It died one day and I plugged it in to charge and it never came back on. I have dropped it before and had the screen replaced but that was about a month before this happened so I don't think that would be what caused it. I just want to make sure that it would be the battery and that I'm not wasting my time or anything.
Add a comment
1 Answer
Chosen Solution
Before replacing the battery try a different charging cable as they can break inside and you would not know. Does your computer see the phone when plugged in.If not its apt to be the cable. If a new cable gives you no joy try a hard reset. This is done by holding the power button and the home button down at the same time for 10 seconds. If none of that helps go for a new battery. Hope this helps
Score 2
Add a comment
Add your answer
Tylin will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 83
