7.9 inch display iPad Mini, with 16, 32, or 64 GB of storage.
656 Questions View all
iPad mini repair: home button activating on its own?
So I just repaired an iPad mini and when I closed down the new screen the home button started activating on its own. Its stuck? Help!!!
Add a comment
1 Answer
Chosen Solution
Usually this means the ribbon cable didnt have tape over it to protect from shorts or you pinched the cable and caused a short in it.
Score 1
I removed some yellow tape from over the home button on the new screen...should I put it back on?
yes also make sure you have no creases in the ribbon cable. It should be folded but not hard bends.
dude thanks so much! I was freaking out, never ran into that issue before...and fixing iPads is extremely stressful. You are a life saver
No problem. Ive been there. Its very frustrating.
Add a comment
Add your answer
Blaine Sieck will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 79
