The MacBook family was first introduced in May 2006 and replaced the iBook as Apple's consumer laptop.
3826 Questions View all
How do I replace hard drive?
Remove old hard drive and put in new one.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
It depends on which of the twelve generations of MacBook you have. The twelve generations cover nine years, and have four major incompatible technical architectures:
  1. A1181 - white/black plastic case, Intel Core Duo/Core2 Duo CPUs, DDR2 RAM, Intel/NVidia graphics, SuperDrive optical drive (2006-2009)
  2. A1278 - aluminum Unibody case, Intel Core2 Duo CPU, DDR3 RAM, NVidia graphics, SuperDrive optical drive (2008-2009)
  3. A1342 - white plastic Unibody case, Intel Core2 Duo CPUs, DDR3 RAM, NVidia graphics, SuperDrive optical drive (2009-2011)
  4. A1534 - aluminum Unibody case, Retina display, Intel Core M CPU, Intel HD graphics (April 2015->)
As you can see, each architecture has its own technique for installing/removing drives.
MacBook Core Duo Hard Drive Replacement
MacBook Core 2 Duo Hard Drive Replacement
MacBook Unibody Model A1278 Hard Drive Replacement
MacBook Unibody Model A1342 Hard Drive Replacement
The new Retina MacBook (released March 2015) does not currently have a drive replacement guide, but the teardown demonstrates that it doesn't use a traditional SATA hard drive. Instead, it uses a PCIe flash module inserted into an M.2 socket on the logic board. It may be a while before replacement drives in this format are available.
So, we first have to identify your computer before anything else can happen. The model number (A11181/A1278/A1342/A1534) will be silk-screened on the bottom case. If you can boot your computer, the more-specific Model Identifier is available from System Profiler, located in your /Applications/Utilities folder. The Model Identifier, which IDs the specific generation of the computer, is listed in Hardware Overview.
MacBook Core Duo Hard Drive Image
Guide
Difficulty: Easy5 - 30 minuten
MacBook Core 2 Duo Hard Drive Image
Guide
Difficulty: Easy15 - 30 minuten
MacBook Unibody Model A1342 Hard Drive Image
Guide
Difficulty: Moderate10 - 30 minuten
Score 2
Add a comment
Most Helpful Answer
Jnani, you did not give us enough information. Go to this site, pick your computer and then follow the guides.
Score 2
Add a comment
Add your answer
Jnani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 3
Past 30 Days: 9
All Time: 413
