2.2 GHz (Turbo Boost up to 3.4 GHz) or 2.5 GHz (Turbo Boost up to 3.7 GHz) quad-core Intel Core i7 processor with 6MB shared L3 cache.
466 Questions View all
Question Closed
Can I change my Mac's complete upper and lower casing?
I have a macbook pro 15 inch retina mid 2014 with intel core i7 4870hq @2.5Ghz turbo upto 3.7Ghz.. It fell down from my hand and it has a dent now! I want to change the entire casing (both upper and lower)... is it possible?
Add a comment
Most Helpful Answer
Yes, you can swap out the bottom case and upper case assemblies on a 2014 Retina. But it probably won't be cheap.
iFixit has replacement guides for both assemblies. The replacement parts are both listed, but marked as "Not for sale"; presumably, these product pages are placeholders for a future time when iFixit has inventory from recycled computers.
MacBook Pro 15" Retina Display Mid 2014 Lower Case Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case
MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Replacement
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly
In the meantime, the parts listings provide us with the Apple part numbers for the two assemblies (Bottom case: 923-0670; Upper Case: 661-8311). This gives us the ability to conduct a wider search for those part numbers, such as eBay/Amazon/other online retailers.
PinnacleMicro stocks the bottom case, and both new and refurbished top cases.
PowerbookMedic also has bottom and upper cases.
All the various upper cases I've located include keyboard, trackpad and battery assemblies.
Be careful; apparently, each generation of the 15" Retina MacBook Pro has a bottom case with a different part number. There may be key differences between them, such as types and placement of screws. Get the 923-0670 model, or it may not fit.
Look at the replacement guides and the various replacement cases. If your MBP works, you may decide that the effort and expense aren't worth it, as long as the computer is currently functional. Odds are, the resale prices of the components will drop as more of the parts filter into the resale market; that probably won't happen until the original warranties expire, which is starting now (July 2015). Since this model was discontinued in May 2015, and extended warranties can take the coverage out to May 2018, it may take a while before the original owners start parting out/reselling the components.
MacBook Pro 15" Retina (Late 2013-Mid 2015) Lower Case Image
Product
$49.99
MacBook Pro 15" Retina (Late 2013-Mid 2014) Upper Case Assembly Image
Product
$149.99
MacBook Pro 15" Retina Display Mid 2014 Lower Case Image
Guide
Difficulty:
Moderate
5 - 10 minutes
MacBook Pro 15" Retina Display Mid 2014 Upper Case Assembly Image
Guide
Difficulty:
Moderate
2 - 3 hours
Score 1
Add a comment
Sure, but proper answer here is that it is never worth the money or the time.
Most people are under the impression that the case clicks on like a speck case or something.. no, everything is glued, screwed, and fastened in, the parts cost hundreds of dollars. Worst of all most of the cases online claim to be new but I didn't know Apple sold new top cases to people? Strange thing about THAT!!! So you're getting some used for a few hundred bucks that someone else sweat on while playing DOTA, ... no thanks.
Stick with what you've got! If you can take pictures we can give hints on how to bang the dent back into place, but really, proper answer here is live with it!
Score 1
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 1,785
