No Image on Galaxy 10.1 Note 2014
Dropped my Galaxy 10.1 Note 2014 and now I have no image. Can it be repaired.
Sounds like you may have damaged the LCD of the tablet. First thing to check is if you have power to the tablet. Does it make any sounds?? Does it connect to a computer?? If it does have power you can take it apart carefully and then check if any of the connects may have become loose after the drop if you have checked all the connections then i would go ahead and order a new LCD and digitizer combo. They are not cheap around $200 and attempt to replace it. Buy the replacement part with the frame it may be more expensive but the repair will turn out a lot nicer and be easier
It does have power and buzzes a little bit when I touch the screen it will not connect to a computer.
Thank you
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 130
