The April 2014 update of Apple's 13" MacBook Air features refreshed dual-core i5 and i7 processors, plus slightly increased battery performance.
125 Questions View all
Where can I insert the PCI-e X4 adapter card into?
(image of adapter i have purchased)
Hi, im trying to retrieve some data from SSD card from my water damaged macbook air 13" early 2014 model. Where do i insert the adapter after i attach my SSD into the adapter? Is there a notch in macbook air 13" early 2015 model (that i recently bought) where i can plug in the adapter directly? if not, where else can i plug in the adapter?
http://www.ebay.com.au/itm/Adapter-Card-... this is the adapter i purchased.
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
I think you'll need to return your adapter as there is a better and easier solution here.
First you'll need to order the following from Other World Computing: OWC Envoy Pro Portable, Bus-Powered USB 3.0 Enclosure For Apple Flash SSDs (June 2013-Current Mac Models).
Follow this IFIXIT guide to remove the SSD from your system so you can put it into the Envoy case: MacBook Air 13" Early 2014 Solid-State Drive Replacement.
Once you have things setup you should be able to access your files from another Mac.
Score 1
Add a comment
Add your answer
keb will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 122
