Second generation of iPhone. Model A1241 / 8 or 16 GB capacity / black or white plastic back. Repair is more straightforward than the first iPhone. requires screwdrivers, prying, and suction tools.
1497 Questions View all
How do I re-attach the bezel to the rear panel?
Theres a gap between the bezel and the rear panel, how do I fix this ?
thank you
David
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
Chosen Solution
the only way to get this done, is to disassemble the phone, fix it and reassemble it.
use the rear panel guide - the bezel is pretty much the last part you can remove on the iphone - so getting to it means, removing everything.
good luck with that
Score 1
Add a comment
If your back panel is all jacked-up you may want to replace it.
Add a comment
Add your answer
david herrera will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 2,214
