Mid 2006 / model number A1181 / black or white case / 1.83 or 2.0 GHz Intel Core Duo processor.
512 Questions View all
Can I use a 2006 MacBook LCD in a 2008 MacBook?
They have 2 different types on inverter cables. If I get the newer Inverter cable, is this conversion possible? Is it a matter of plugging in the new cable, or do I need a newer inverter board as well?
I had a 2006 macbook where the graphics card took a dump. I found a newer logic board with the case bottom on eBay so I bought it. I didn't realize that the inverter cables were different until I went to install the display.
Thanks in advance!
Add a comment
New Battery = Faster iPhone
Fix Kits starting at $16.99
1 Answer
Chosen Solution
Hey TR, the MacBook model A1181 LCDs for 2006, 2007, 2008 are interchangable. It will work but the difference consists of the frame and the core duo models have three airport antennas.
-Let me know if this helps.
-Please accept this as the answer if it answered the question.
Score 1
Comments:
I see where you are coming from, but on Apple's support site, both computers have the same size display with the same resolution. The only difference that I see is the graphics cards have different specs.
Thanks for the quick answer, but your answer doesn't give me an exact reason why it can't be done.
by
Sorry, I was thinking about a different model when I was answering. Please look at the edit again. Ignore what I said last time.
by
The display has the old airport cables attached to it, so I'm going to try it out and will replace the airport card if it doesn't work,
by
Add a comment
Add your answer
TR Hodges will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 1
All Time: 64
