Fourth generation iPhone. Repair is straightforward, but the front glass and LCD must be replaced as a unit. GSM / 8, 16, or 32 GB capacity / Model A1332 / Black and White.
3230 Questions View all
Why my iPhone boots and screen starts to be red?
my power/lock button stopped worked today, so I opened the iphone and replaced it, when I boot the screen is black with backlight on and then starts be red but only on left side of the screen. Maybe I damage the connector of the screen?
During the assembly I lost about 2 screws
Add a comment
1 Answer
Chosen Solution
Hey Roberto, this usually happens when all of the screws aren't in the correct place for the metal part which is usually found covering the digitizer. Please redo it make sure the screws are in the appropriate place because you can damage the logic board by doing this. A common mistake that can cause this is that the longer screw is put in the incorrect spot or missing screws.
-Let me know how it goes.
-Please accept this answer if it answered the question.
Score 1
I think I need to buy a new set of screws from ebay, thanks a lot for the answer, I will update
If this helped in any way please accept this as the answer and thank you.
Add a comment
Add your answer
Roberto Meneses will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 55
