MacBook Pro models with 13" displays
5537 Questions View all
I TUNES is not responding how do I force quit
i have macbook pro unibody 2009 with yosemite as an os,I tunes is unresponsive I tried the usual methods to quit unable to do so,kindly explain how to sort ou this issue thank you narayanan lakshmanan india
Comments:
I had to shut down the on button and restart is it an indication that there is an issue in the hard disc or please explain why should it happen if possible please explain how to avoid this in future tank you narayanan lakshmanan india
by
Add a comment
Mac RAM Kits
Speed up your Mac. Max out its memory.
Mac RAM Kits
Get more memory out of your Mac.
1 Answer
Chosen Solution
In the upper left go to "GO -> UTILITY -> ACTIVITY MONITOR" then in the search put itunes then highlight it and click the white x in the black circle in the upper left corner, a popup will come up and choose force quit. This should work if it doesn't then you need to shut down and restart your computer
Score 1
Add a comment
Add your answer
NARAYANAN LAKSHMANAN will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 45
