The second generation of the iPad with Wi-Fi, GSM and CDMA models. Some models were refreshed before the iPad 3. Repair is difficult and requires heat and prying.
926 Questions View all
Help me fix my iPad 2
I dropped my iPad 2 the other week and it was working perfectly fine, I went to go turn it on today and the screen was black and wouldn't turn on. You can here it Charing when you out the charger in but that's about it. Can someone please help me?
Score 1
Comments:
how do i fix my iPad 2
by
Patrick Kodi, depends what's wrong with it.
by
Add a comment
Free shipping on all orders over $100 or containing a Pro Tech Toolkit!
Browse Our Store
Most Helpful Answer
It sounds like a problem with the LCD. You will need to remove the screen in the iPad and try reseating the LCD cable in to the motherboard and the back of the LCD. If that doesn't help, you will need to replace the LCD.
Score 1
Add a comment
I agree with David. See if it's recognized in iTunes. If you can hear it charging, and it's recognized, then it's most likely a display problem. Hopefully the lcd cable came loose. If not, you need a new LCD display. Other than that, could be the backlight, but I'd try the LCD first.
Add a comment
Just my opinion and also I am no expert to this kind of problem just tell me if I went wrong, so I agree with David that the LCD is indeed broken after that damage you did so probably you would have to do a hard reset to make sure that the LCD is back on again by holding down the power button and home button the same time, if it didn't work try taking it to the apple store or replace its LCD.
Add a comment
When I make a video on my iPad 2 am not getting audio but when I listen to music or watch a video am getting audio,can you help me please
Comments:
This is a microphone issue
by
Add a comment
Try holding the power button and the home button both at the same time for about 15 seconds. If iPad does not come on the LCD most likely came unplugged after dropped. Very common on this iPad 2. Worst case scenario you will need a new LCD
Add a comment
Disassemble. After checking out the parts, reassemble if broken and send to Apple.
Add a comment
Add your answer
lani will be eternally grateful.
Past 24 Hours: 0
Past 7 Days: 1
Past 30 Days: 2
All Time: 262
