The PlayStation 3 (or commonly known as the PS3) is the third home computer entertainment system produced by Sony Computer Entertainment, and the successor to the PlayStation 2. It was released November 11, 2006
781 Questions View all
Question Closed
I need help disassembling my Ps3 model: CECHG01
I skipped step 19 because my model didnt have those clips. I also could not find my memory car reader. I have an idea of what it is but i'll wait on some advise before i do anything. I also skipped steps 22-23 thinking i didnt have the memory card. Lastly i was able to get to step step 27 but i couldnt lift the motherboard off of the heat sink. it appears to be held stuck by small metal parts.
the 1st 4 photos are all around of how far i was able to get after step 27.
the 5th one is what i believe the memory card to be.
the last 3 are the brackets that i think are keeping me from lifting the motherboard.
I'll be waiting for any help you can give me!
Add a comment
1 Answer
Chosen Solution
That is not your memory card it is your wifi card...carefully disconnect the ribbon cable and remove the screws. Then remove the ribbon cable from your motherboard both by lifting the colored tabs. Once this is out of the way remove the optical drive ribbon cable from the MB the same way. Then if you've already disconnected the fan cable from the bottom of the unit, you can push the clip on the front in to disengage and the top plate will pivot up towards the back...it will have some resistance due to the heat paste but if you've gotten all the screws it will come up.
Hope that helps!
Score 1
1 Comment:
Thank you so much for your help! I was able to get past this but unable to fix the PS3. The was no place for the thermal pad. also i could not remove the fan. But thanks you again!
by
Add a comment
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 379
