plastic camera bracket removal
How do I get the small plastic camera bracket off my old screen and back on my new screen?
Hi Jason,
The easiest way to remove the plastic camera bracket, is to get a heat gun or reflow station and go over the front of the screen, this softens the glue and allows you to easily remove the bracket. :-)
Use hot air (100-200 deg C) for 20-10 seconds, the pry off using fine tweezers or a needle. Be careful as it's springy.
Next to it, there is a tiny square piece of white plastic, make sure to transfer it as well.
HEAT works best i usually lightly scrap the glue with a sharp knife
Past 24 Hours: 0
Past 7 Days: 0
Past 30 Days: 0
All Time: 73
1 Comment
Thank you, worked great
by Jason Hammond
