Inverter connection Help, Core duo to Core 2 Duo board
Hello,
Wondering, if anyone can help me on this one. I'm upgrading from a 1.83GHZ Core Duo to a 2.13GHZ Core 2 Duo A1181 Macbook and don't have a core 2 duo display. I just have a core duo with 2 airport, black, grey wires, a LCD display data cable and the inverter cable connection to the board is block type 4-wall press-in. The core 2 duo board that I wish to use has the flat slide-in JST connector pins on the logicboard to accept the inverter cable, however the core duo display invertor cable from the display end is press-in or block type and won't fit onto the core 2 duo board.
Can I simply get a penryn inverter board and flat 3-wall cable to connect to the JST connector on the core 2 duo board to make the display work or will I need to get a core 2 duo display.
Thanks
Any help would be appreciated.
1 Comment
Thank you very much for the response. I will try that procedure.
by Tony
