battery problem after replacing SSD MB PRO late 2012
Hi,
I replaced my SSD with a Jetdrive 720 SSD very carefully, following instructions.
Everything seems to work fine except for the battery.
Magsafe shows solid green light, but is not charging.
When I remove it my macbook shuts down immediately and powers up by itself when I plug it back in.
I have tried PRAM and SMC reset several times, not sure if the latter worked. (Magsafe light solid green, not changing)
SSD firmware is up to date. Verify disk reports no problem.
I have performed an extended hardware test which reported no problem.
(I'm assuming a logic board problem would have been reported, had I damaged the logic board during the process?)
What could I have done wrong? Is there anything I could try without having the battery replaced?
Thanks in advance for any advice!
Christine
Model Information:
Serial Number: D862431P2WSF9557V
Manufacturer: SMP
Device Name: bq20z451
Pack Lot Code: 0
PCB Lot Code: 0
Firmware Version: 511
Hardware Revision: 000a
Cell Revision: 1169
Charge Information:
Charge Remaining (mAh): 6153
Fully Charged: Yes
Charging: No
Full Charge Capacity (mAh): 6234
Health Information:
Cycle Count: 298
Condition: Replace Now
Battery Installed: Yes
Amperage (mA): 0
Voltage (mV): 12495
